Dominator or GMPP crate engine ECU?
I have a 454 LS3 ... nothing too fancy other than a Harrop ITB.
I'm trying to figure out if I want to install a dominator ecu or a gmpp crate engine ecu (I have both here). I know virtually nothing about tuning and will eventually get it dyno tuned, but I would like the engine to at least be able to start up and idle so I can bleed coolant, etc...
Since i have to do speed density tuning (because of the ITBs) am I better off just using the dominator?
If I weren't using ITBs I'd probably just use the GMPP controller, but what concerns me is I find a lot of threads that go:
'w00000t, got my ITBs'
'car can't idle without dying, oh well, ITBs are cool'
'dyno tune tomorrow!'
*crickets*
*crickets*
Fortunately the Harrop seems tuned well out of the box (in terms of throttle opening in sync)
Alex you should contact Westers Garage in Alberta for help with the "917". They are highly regarded.
Also contact some other tuners. They may even have a file that is close to your 454 LS3 ITB build. It might be close enough to get you up and running. Then off to a dyno tune to finish it off. You might be able to use the GMPP setup.
Last edited by mrvedit; 10-09-2015 at 10:46 PM. Reason: Remove link to non-sponsor. (Sorry)
