LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   SD DTC's (https://ls1tech.com/forums/pcm-diagnostics-tuning/1809189-sd-dtcs.html)
BOTTLE ROCKET Nov 7, 2015 10:28 AM
SD DTC's
For running a SD tune, do I need to disable 101,102,103, or leave enabled and set "no mil light so the computer will see it after I've set MAF to 0?
Thanks
redtan Nov 7, 2015 02:06 PM
Don't disable them, you need those to be active.
Just hide them so you don't get a CEL all the time on your dash.
BOTTLE ROCKET Nov 7, 2015 06:55 PM
Thanks redTan
I will check "No Mil light"
© 2026 MH Sub I, LLC dba Internet Brands
