Obd2 speed doesn't match The guy tuning my car ran into an interesting situation today. He said when checking the speed through the OBD2 port it showed twice what it should have. The speedometer is showing the correct speed and the transmission is shifting correctly. The car is a 1984 Corvette with a 2001 Corvette LS6 motor and a 1999 Camaro 4l60e transmission Any ideas what parameters he should check? |
What is your speedo driven from...? |
Originally Posted by joecar
(Post 19072666)
What is your speedo driven from...? The speedo and the transmission shifting are accurate, it's the obd2 output that looks exactly double of what's on speedo. |
The Dakota box can be configured to halve or double the pulses per mile, which may have been necessary to get your speedo to work correctly. That could explain the difference. |
On engine swap vehicles I always set up the speedometer in the pcm and get it reading correctly (correct tire size and gear ratio) and verify it with gps. Once the speedometer is correct in the computer then I worry about the gauge in the car since 99% of them have to be programmed also. |
Originally Posted by LSX Power Tuning
(Post 19075161)
On engine swap vehicles I always set up the speedometer in the pcm and get it reading correctly (correct tire size and gear ratio) and verify it with gps. Once the speedometer is correct in the computer then I worry about the gauge in the car since 99% of them have to be programmed also. The Stack speedometer is expecting to see about 35,333 pulse per mile, based on the OEM tire size of 225/45-16 with a 42 tooth wheel. |
| All times are GMT -5. The time now is 02:41 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
