LM7 Swap wiring issues
I have a code u0107, Lost communication with TAC module.
I'm running a 5.3. with a 4L60E trans.
The TAC, APP, harness and engine are supposed to be from the original 05 Tahoe, came from a salvage yard. PCM was purchased and programmed for standalone from LT1SWAP.com.
I rewired the harness per LT1SWAP.com.
I have checked grounds, TAC, APP, and PCM wiring. Throttle body also.
From posts I know about the SB on the throttle body, but wires checked good and wiggling them doesn't change that, still a possibility...
TAC part #12588923
PCM part #12589463
APP # 090704-0930A-A ?? doesn't look like a gm part # but I pulled this myself from the vehicle.
I plan on clearing codes and testing again.
Will the PCM maintain codes if the keep alive power is removed?
Any ideas would be appreciated, don't really have any donor vehicles I can swap parts with to verify operation.
Thanks for any help.
Tom T
54 Chevy 3100 swap
