Bank 2 Misfire - the WHOLE bank
Well, after getting the LS1 in place, and all my wires hooked up, I am getting a bank 2 (cyl 2,4,6,8) misfire. I get no spark, and I'm not sure about injection. It appears all ign. signal wires have continuity to the PCM, the bank is getting a full 12v at each coil tower, and the ground is good. Any ideas for what is wrong? Its an '02 Camaro engine and as a side note I was reading the manual on the Crate LS1 and it layed out different pinouts for the PCM IGN Control than what my '02 engine had. The discrepency being the following:
Crate Engine
Red Connector
PCM 13 Red/Wht
PCM 57 Dk Grn/Wht
PCM 54 LT BLu/Wht
PCM 52 Ppl/Wht
'02 Camaro Engine
Red Connector
PCM 67 Red/Wht
PCM 29 DK GRN/Wht
PCM 61 LT Br/Wht
PCM 28 LT BLU/Wht
Crate Engine
Red Connector
PCM 13 Red/Wht
PCM 57 Dk Grn/Wht
PCM 54 LT BLu/Wht
PCM 52 Ppl/Wht
'02 Camaro Engine
Red Connector
PCM 67 Red/Wht
PCM 29 DK GRN/Wht
PCM 61 LT Br/Wht
PCM 28 LT BLU/Wht
What harness and year pcm are you using?
Sounds like you don't have the coil harness plugged in on one side or it's messed up.
I guess if the year of the PCM is an issu
Well so you can get the car to run on 4 cylinders? If that is the case then you can unplug the one side and it won't make a difference right?
What year is the crate engine?
Break down the whole setup for me...
At this moment, the 2001 Camaro PCM has a 1999 Camaro binary and is hooked up to a 2002 engine and harness. The 2nd bank of the 2002 engine does not fire. The first bank runs perfectly. If I disconnect the 2nd bank's ignition harness, the situation obviously does not change.
Well...
1) signal/power/ground issue in the harness to the pcm
OR
2) messed up pcm.
2) messed up pcm.
Thanks for the help man.
LS1Tech Co-Founder
I'd swap the pcm first, and eliminate that as the culprit. Since the problem is not having spark to both sides, makes me think pcm, or... since it won't run on that side, it's not getting fuel or spark? If it's not getting fuel the injector driver's in the pcm might be messed up.
