Notices
PCM Diagnostics & Tuning HP Tuners | Diablo | Pantera EFI
VE Table Airflow Correlation to Horsepower?
Old 03-03-2016, 07:52 PM
joecar's Avatar
Also as a side note, VE can be calculated from MAF as follows:
VE[g*K/kPa] = MAF[g/s] * DAT[K] * 120[s*rev/min] / RPM[rev/min] / MAP[kPa] / N
and for N=8 cylinders this becomes:
VE[g*K/kPa] = MAF[g/s] * DAT[K] * 15[s*rev/min] / RPM[rev/min] / MAP[kPa]
where DAT[K] is dynamic air temperature (air temperature corrected/modelled for manifold heatsoak).
The implication of this is that you can correct the MAF (with VE disabled) and calculate a new VE from it ( if the injector tables are correct )
In EFILive there is also a VETABLE lookup pid which allows you to do the inverse of the above, i.e. correct the VE (with MAF disabled) and calculate a new MAF from it.
joecar is offline
Old 03-08-2016, 09:57 AM
joecar's Avatar
Default VE Table Airflow Correlation to Horsepower?
Originally Posted by joecar View Post
( and note that rearranging the IGL P*V=(m/M)*R*T gives m*T/P=V*M/R ).
m*(T/P) = V*(M/R) is the cylinder volume converted to airmass in normalized form (normalized for absolute temperature and absolute pressure).
joecar is offline
Old 03-08-2016, 02:10 PM
Super Hulk Smash
JakeFusion's Avatar
That's awesome, Joe.
I'll see if I can map that into HPTuners with some custom PIDs. I know it's possible in EFILive.
Last time I tried in HPT, I kept getting an error.
JakeFusion is offline
Old 08-06-2016, 02:35 AM
Any update, progress with an algorithm to display VE table in units of g/sec in HPTuners ?
Fullpower is offline
Old 08-06-2016, 10:07 PM
The scanner does this while logging.
eaglegoat is offline
Quick Reply: VE Table Airflow Correlation to Horsepower?
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
