questions concerning harness mods
Old Mar 31, 2016 | 01:30 PM
taz68camaro's Avatar
Default questions concerning harness mods
I have a few questions concerning stock harness mods. I have an 08 Trailblazer SS 6.0 with an E67 pcm and a 4L60 that I want to drop into a 68 Camaro. This is uncharted waters for me so please don't beat me up too bad for asking what seems to be a stupid question. And if there is a thread already posted for this any redirection to that would be awesome. These are the circuits I think I can eliminate. Any advice would be sooooo appreciated. Also, if there are other circuits I can eliminate, please let me know. thanks everyone!
1) rear 02 sensors (would replacing the front 02's with wide band be cost effective?)
2) anti-lock brake circuit
3) 4 wheel low circuit (since I'm converting trans to 2WD)
4) cruise control
5) there are 3 different wires pertaining to vehicle speed (VSS): one is on J1 pin 24 labeled as "not used", another on J1 pin 25 labeled as engine speed signal and another on J1 pin 39 labeled as VSS. which of these are used in cruise control logic and which one is used for speedometer?
6) brake boost vacuum circuit
7) fuel tank pressure circuit
8) EVAP canister circuit
9) DOD circuit (can I just plug the block towers after DOD has been removed from ECM?)
10) VATS
That's enough for now because I don't want to take up too much of someone's time. But even if I screw something up the knowledge gained from this is priceless. Thanks again. Most of the threads I have read are using a T56 but I'm going to give this car to my daughter someday and I want it to be as enjoyable as possible for her.
Old Mar 31, 2016 | 03:34 PM
Cyrperformance's Avatar
http://lt1swap.com/geniv_harness.htm
Leave rear O2's. Run separate wideband, I have the PLX unit and AEM and really like them. If you are going to have someone else tune it, depending on who you go to, you may not even need one as they will have it already.
Old Apr 1, 2016 | 09:38 AM
So I should leave the rear O2's? W/O a cat? I should have mentioned I am using Hooker headers? NewB here, sorry.
Old Apr 2, 2016 | 12:41 PM
Sorry, leave out rear O2's.
