Car Got Wet, Now it's Pissed.
Out on my honeymoon right now with an 02 trans am, ran perfect before it had to drive through some puddles. Next morning,
- tach, fuel, temp gauges not working
- service vehicle soon, service vehicle, abs inop, air bag lights are on
- after starting car, it bogs down hard when accelerating. Pops a bit extra at times like it's running rich
- after a few mins of the stumbling, it drives fine but gauges and lights are not fixed.
Any tips on where I should focus my efforts for a potential quick fix? Kinda busy with the rest of the honeymoon plans still underway! Thank you in advance
If you hit a good size puddle you could have sucked/splashed some water up into your air filter. That would explain the bogging down and sputtering, you're trying to suck air through a wet filter (not efficient) and pulling droplets of water into your intake (hence the sputtering).
As for the lights, obviously something in the electrical system got wet. I've had this happen several times over the years and 3 out of 4 times the issue resolved itself over the course of a couple of days after everything dried out. If it doesn't fix itself then start going through the process of troubleshooting the electric system to find out what the water got into and tore up.
If it was me (on my honeymoon) I'd go to a parts store, replace my air filter, have them read my check engine light to see what code it may show (just in case) and then, if the car is running fine other than the gauge issues - enjoy my honeymoon and worry about it when I got home. Just make sure to keep an eye on mileage and fill up every couple of hundred miles!
O2 Sensors/Harness got wet? Are they 'exposed'/frayed?
-KP
-KP
Thanks for all the replies everyone!! Was lucky enough to make it home where I'm going to dig in to the problem with your suggestions.
Some odd things I found out further:
- OBD scanners can't communicate. Fried ECM maybe?
- The bogging acceleration is only during the first minute of driving, and is generally remedied by going past half throttle which jolts it back into acceleration. It won't really fall back into bogging after that, until the next ign cycle.
I also have access to a Tech 2 scanner at work, going to give that a try.
Factory service manuals are below through 2000, maybe look at the diagnostics for a few of symptoms and see if you can find a common denominator.
www.mediafire.com/?40mfgeoe4ctti
Apparently the puddle was the coupe de grace for an existing iffy situation. Thanks for the report!
