Notices
PCM Diagnostics & Tuning HP Tuners | Diablo | Pantera EFI
idle hunting surging 4.8 to lq4 swap with cam and dual valve Springs
Old 08-05-2016, 11:30 PM
Restricted User
If its DBW, you can ignore the idle screw and TPS comment.
JoeNova is offline
Old 08-05-2016, 11:40 PM
kevin87turbot's Avatar
The VE table is very close to a stock 2006 4.8L VE Table in the first few columns.
See the comparison table below. That seems very odd...
kevin87turbot is offline
Old 08-05-2016, 11:46 PM
I'm starting to get a little confused one person said to use the same ve you're saying it's similar so that's odd? literally I put in a lq4 with a cam and Springs after blowing up my 4.8 drove it around a few days under 25% throttle to make sure that it was a decent motor because I already did this once and then drove it to my tuner to be Dyno Tuned because he said the files between Motors are very similar and won't hurt anything as long as I don't go into fuel enrichment and boost and then was Dyno Tuned I can't remember if I had these issues before the tune or not but no matter who changed the tune or what changes are made the problems stays the same the problem seems to be intermittent like the idols not perfect but sometimes it will surge sometimes it won't obviously I hope it's the tune because I've gone through the truck and everything seems perfect so if it's not the tune I'm pretty much pulling stuff apart I am not a tuner I am barely a novice I'm pretty good with transmission I did my own segment swap I understand what some of the tables do but definitely don't understand most of it or what's normal stuff like that I don't expect anybody to spoon-feed me I guess what I'm saying is if you're going to give me some advice be ready to explain to me how to make the changes I truly appreciate everybody's information it is helpful I'm just frustrated with my truck so I've been going crazy with it lol doesn't seem too search what I'm doing donuts or running in the quarter mile LOL
chevyboi925 is offline
Quick Reply: idle hunting surging 4.8 to lq4 swap with cam and dual valve Springs
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
