still can't get oil pressure reading
Reviving an old thread, but was curious as well. I have an 02 LQ9 and would like to have the oil pressure on HP Tuners but also available on my OBD2 stream. So, I understand adding the wires/pins to the PCM harness and getting the correct sensor, but when you are logging Oil Pressure in HP Tuners, did it “know” it was oil pressure, or did you create a custom readout? In other words, is the computer recognizing it as oil pressure and thus it likely available on the serial OBD2 line?
I have custom gauges that use the OBD2 through the computer, and it’d be great if oil pressure was on the stream to avoid running its own sensor to the gauges.
I know you said it had been a while, but do you recall if that was needed to get it to work? Like maybe it didn’t work pinning it alone, but flipping that switch and it did? I’m just wondering if that’s a feature hp tuners added later in system settings, and thus the old posts saying that the re-pinning didn’t work for some people.
So i tested this. Of course I dont have a sensor hooked up, but HPT shows Oil Pressure as supported for an F body on a stock tune file.
With or without enabling Oil Pressure in the System Tab.
This is all I can help with. It's worked in all the harnesses I've added it to. If HPT can read it, Id think your dash thing would too.
Good Luck
Good Luck
Good Luck
Good Luck
#33
Unless it’s not in my data stream since it wasn’t there from the factory... Agree, I’ll just have to try it, but it’s kinda an experiment I’d rather not do for nothing (buy a sensor, wire it into PCM, etc. only to end up using the different style Dakota digital sensor that came with the gauges. But you’re right, I’ll just have to try. Was hoping someone with an early truck 411 PCM might have tried this already.
I also run RealDash with an OBD2 bluetooth adapter on the OBD2 port, mounted a 6" screen for extra gauges, and have oil pressure and water temp gauges on the screen running off the PCM data, works great.
#34
I suspect it will work because the truck PCM is the same as the Holden PCM's of that era and I am using one of those and oil pressure works for me in HP Tuners.
#35
https://phantombullet.net/files/Hold...M-Pinouts.html
Maybe you could 'write entire' and install a different operating system, like the holden or vette one. But id ask to make sure its a compatible OS to your PCM.
https://www.hptuners.com/help/vcm_ed...menu_write.htm
I guess what I said earlier isnt necessarily the case because the PCM's can be the same, but the operating system can be different.
#36
I'll give you a link to the holden PCM pinouts so you can compare where the pins are on those.
#39
I added this to another 0411 with a Camaro OS recently.
Aftermarket harness, and they used the oil pressure ground for O2 ground as well.
I spliced the oil pressure ground to the O2 sensor ground.
Worked fine. We are actually is to measure converter cooler line pressure.
GM changed O2 sensor grounding even pre P59. The earlier harness didn’t use that ground
The following users liked this post:
lumen8 (12-30-2020)
#40
