Fuel pump primes sometimes, but no start
Ok, having a really weird issue. Got my 67 camaro with LS2 swap done a few months back and has been running perfect. Used a PSI conversions harness and ECM. One day I turned the key, fuel pump primed, but no start. Then when I turned the key again, no fuel pump at all. Every once in a while the car will prime, but not start, and then next time I turn the key the pump is not working again. Also noticed the fans are coming on while cranking over. Tried new relays, checked fuses...no luck. When I hardwire the pump it stays on so it's not the pump. Any ideas please... it's driving me crazy.
sounds like a short somewhere.
The fan run signal is a ground trigger, if the wire rubbed somewhere it would ground out and run the fans.
The fuel pump is a 12v+ signal and if shorted 0 volts would get to the fuel pump relay.
Can you check live data on your scanner? During the problem what is your coolant temp? I think the PCM can shut off the motor and run the fans if it thinks its overheating.
