Notices
PCM Diagnostics & Tuning HP Tuners | Diablo | Pantera EFI
Tutorial-MAF Scaling for High Horsepower Setups
Old 09-07-2018, 12:54 PM
  #41
ddnspider's Avatar
Darth,
Whats the units on those tables? Are the delays in seconds and the correction unitless?
ddnspider is offline
Old 09-07-2018, 12:58 PM
  #42
joecar's Avatar
Here's what I see (2 match Darth's pics, the others don't):
joecar is offline
Old 09-07-2018, 01:00 PM
  #43
joecar's Avatar
( I just remembered that Integrator (old OBD term) means STFT (newer OBD-II term) )
joecar is offline
Old 09-07-2018, 01:22 PM
  #44
ddnspider's Avatar
That's gold right there! Never would have known that.
Old 09-07-2018, 03:13 PM
  #45
Darth_V8r's Avatar
Looks like Joecar is onto it. The units in the proportional tables I posted are non-units. it's a scalar number. In the integrator side, it is seconds, and there is a multipler. The integrator is the STFT, I'm sure. Really, the long term fuel trim is a slower acting integrator. The proportional is what keeps the fuel bouncing back and forth from 100 to 800 mV so it can make sure it is near stoic. Pretty sure that's what that base correction is you posted below. I just had to reduce the proportional numbers. stock on mine in HPT were 128. I had cut them to 33 for the injectors and ended up at 11 for the tune scaling. not sure how that translates into EFILive, but I thought it was worth passing along. What it was doing was similar to when you put bigger injectors in and it swings from 14.0-15.5 instead of staying near stoic (going 14.3-15.0 or the like). Hope that explains it better or helps confirm that what you found in EFILive is matching what I found in HPT.
Darth_V8r is offline
Old 09-07-2018, 03:38 PM
  #46
ddnspider's Avatar
good info Darth!
Old 09-18-2018, 03:33 PM
  #47
ddnspider's Avatar
joe and Darth....it seems this last one last thing will be my final conquest when it comes to a scaled tune. Since scaling the tune I CANNOT get it to idle richer than ~15.5-16 whenever the fuel trims are turned on. I realized I hadn't tuned the car since March when it was cold out, so for fun I set it open loop to see how off the AFR would be from a cold start since its like 100* outside.....dead nuts on 14.6. Idle and cruise are perfect....until I go back closed loop. I tried the following:
-Set STFT base correction at idle to 25% of stock and 200% of stock-result stays lean
-Set the base delay to 50% of stock and 200% of stock- result stays lean
-Tried combinations of the above and still couldn't get it to idle richer.
I feel like I'm missing something or a table that I need to change to pull the AFR down in CL. Thoughts?
Old 09-19-2018, 01:54 PM
  #48
joecar's Avatar
Trying moving the O2 switch points (table B4105).
joecar is offline
Old 09-19-2018, 01:56 PM
  #49
ddnspider's Avatar
I had them set at 450mV, I believe I tried 350 and 600, but I can't swear to it. I'll try it again.
Old 09-19-2018, 02:01 PM
  #50
Darth_V8r's Avatar
Mine reads lean at idle also, but that's on purpose for me. What's interesting is my AFR gauge reads lean, but on the logs, it is within 2% lambda error. So I go with the logged number. AFR logs match the last dyno run I did. Kind of weird. i've learned to live with it. At higher load, the gauge and the logs match up. probably not helpful to you though, unless it is just the headers messing with the readings at low flow?
Old 09-19-2018, 02:10 PM
  #51
ddnspider's Avatar
At WOT it does go to commanded AFR, but thats because WOT is OL I assume lol. At cruise it's not even that leave, it's mostly at idle. I assumed, perhaps falsely, that I should be able to sway the fuel trims lean or rich via SOME combination of tables.....but can't figure out which table that is. I can literally idle the car OL @ 14.6, flash the same tune with CL, and watch the fuel trims say pull 10% fuel and the wideband matches.
Old 09-19-2018, 05:08 PM
  #52
Darth_V8r's Avatar
You're right - WOT is OL. On mine, even cruising, everything lines up nicely.Just for some reason at idle, it reads lean. i've long since assumed it was false lean, possibly incorrectly.
Old 09-19-2018, 05:27 PM
  #53
ddnspider's Avatar
I definitely think it's truely lean as I can hear the difference in the motor when I change it to OL idle and the wideband and fuel trims both show lean/pulling fuel. Would just LOVE to understand it haha. Right now I'm using a hybrid tune, the PE table it set to 14.6 and 0% throttle up to 1200rpms and above that goes CL. OL idle, CL cruise, OL WOT haha.
Old 09-20-2018, 12:52 PM
  #54
Kfxguy's Avatar
good info guys. thanks for this thread. i'll reference this when i decide to use my maf again.
Kfxguy is offline
Old 09-20-2018, 12:54 PM
  #55
ddnspider's Avatar
Cool, glad you enjoyed it
Old 09-20-2018, 01:08 PM
  #56
Kfxguy's Avatar
your always a helpful fellow. forum needs more guys like you. i know we do have a few though!
Kfxguy is offline
Old 09-20-2018, 01:09 PM
  #57
ddnspider's Avatar
Haha, there's a couple members I bicker with that I could do without, but I try to be helpful LOL.
Old 01-16-2019, 10:05 AM
  #58
NemeSS's Avatar
Thank you for the detailed write up. Its exactly what i was looking for.
building a remote mount turbo lq4.
I need ac. And dont want a cramped engine bay.
car is a formula. And im not cutting or modding the front cover in any way. So its getting a a2w setup
I need silky smoove driveabilty out of boost.
stock lq4 w ls9 cam. 3k stall. I would b happy w 550-600rwhp tbh. Keeping the stock rear. I have a fabricated narrowed 9inch. But dont plan on using it anytime soon on the car.
shouldnt b tol hard to get what im asking for. With a maf setup and about 10psi
NemeSS is offline
Old 01-16-2019, 10:26 AM
  #59
ddnspider's Avatar
Cool, glad you liked it. You may try and see what it does before scaling at what power level, you may not even need to scale.
Old 01-26-2019, 09:50 AM
  #60
01ssreda4's Avatar
Does the engine size selection (under engine tab) do anything when you change it?
01ssreda4 is offline
Quick Reply: Tutorial-MAF Scaling for High Horsepower Setups
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
