any tuner guys wanna peek at my file for some idle help?
Location: From Saint Louis, Living in California Bay Area
The car surges so hard at idle that I have to give it gas to run, but its surging so hard that it hits on the converter and tries to take off??
its a 6.0 LQ4
Cam is 231/239
-lobe separation 115
-intake centerline 112
-valve lift @1.7 is .640/.629
78mm turbo setup
80LB Dekas
3800 stall non lock up
th400 full manual
3 BAR OS
Base Fuel PSI is 55PSI roughly on the gauge.
its a 6.0 LQ4
Cam is 231/239
78mm turbo setup
80LB Dekas
th400 full manual
3 BAR OS
I'm using the "EFISource 3 BAR... I did see that it only shows 10kpa no matter what throttle setting or boost psi it has... that's odd
http://www.efisource.com/shop/ls1-st...ar-map-sensor/
Big thanks owed to you my friend... started investigating the wiring and pulled the plug off of the map sensor and found a pin was bent up and around its female counter part... got it straightened out and boom car is registering normal map pressure and idles like a champion! Thanks for the quick responses!
ANOTHER LS1Tech feel-good story! Gotta love it!
