Bench Harness Diagram for E67 HP Tuners
I've been running Holley EFI on my last two swaps and about to purchase HP Tuners pro for my latest engine purchase a 5.3 LH6 out of 2007 gmc envoy.It has a e67+t42 tcm,I took all the harnesses,pedal and would like to start it before i put it in next project.Also I took a few e67 C1 and OBD2 plugs from junkyard so i can make a bench harness.Seeing if anyone has made one for a e67 trying to gets some ideas and diagram.
Thanks,
Brian
Thanks,
Brian
Thanks Steve,Chuck,Lance for the great info.I know where a wrecked car is with E67 harness still in it have to go and grab whole harness.Didn't realize I needed all the connectors for a bench harness.If it's not there I'll give Lance a call.Thanks so much I appreciate the help.
Brian
Brian
Just a quick question are you guys running that resistor between terminal 6+14 on obd2 plug.Mine has one from factory.Plug was pulled from same vehicle I got motor and ecm from 07' envoy.I took a pic of it.Thanks
I would also wire the High Speed GMLAN wires slightly different than the factory. From the factory they run from the DLC to the TCM and then from the TCM to the ECM. The problem with that is if for some reason you were wanting to connect to a manual vehicle that does not have a TCM, you wouldn't be able to connect to the ECM because the High Speed GMLAN circuits would now be open since the TCM connector is unplugged. You would have to install jumpers into the TCM connector to get it to work. If you wire the High Speed GMLAN wires in parallel from the DLC to the ECM and TCM, that will no longer be an issue. I've attached the factory schematic for an 08 TBSS which is wired the same as your 5.3 Envoy. Don't worry about Pin 2 at the DLC. You won't need that. I have also attached a schematic showing how to modify the High Speed GMLAN wires. You won't need to connect anything to Pins 37 and 38 of the TCM connector.
