Twin turbo 6.0
Have you had any operational issues worthy of note?
not really with this tune it was a little lean at 11.7 seems to be ok but I have never tuned a car with a computer all old school stuff in the past just wanted to see if anyone saw something that stands out. the first test at the track it turned the headers red it pulled the timing down to 2 degrees fixed that and this is the latest test pass. thanks
If you have a tune logged, how did you tune it without a computer?
11.7 is on the rich side of stoichiometric; or do you mean it WAS lean and NOW at 11.7?
I meant this is the first time tuning with hp tuners all my other cars were not fuel injected the car is twin turbo on 10 lbs of boost I think it should be around 11.3 11.4 afr disregard the one that says cur[rent tune the run8 is correct log
run8.hplfirst track.hpt 8 10psi.hpt
