Anyone running an AIM Strada XMS Street Dash?
Two Step Launch
Hi, Yes the Meth Injection can be calibrated using MAP/RPM for amount, 8x8 OR 64 points.
The Two Step can reduce the timing by up to 100 degrees.
I also have a Studder Table for Start Line Launch that rotates the cylinders in YOUR order choice keeping them all HOT and clean.
Data Logging is another feature with 24 Channels @ 200 Hz. (1 mb flash)
You can choose the Spark Advance separately for EACH cylinder as is your fuel flow choice separately for each cylinder.
Lance
Lance
