Lq4 tune question HPTuners
So I am putting together an LQ4 cammed/stalled with 799 heads in an A4 4l60e fbody, headers, 3.73s, LS6 intake, which is a recipe I thought would be very common.
I bought HPTUNERS thinking there'd be a baseline tune for me in the repository for what I thought was a common combination, but not seeing it.
Is it out of line for me to ask someone for a good baseline tune I can at least plop in this thing to get it started/idling? I also have a wideband so I should be able to tinker safely once it's rolling and eventually work my way up to safe WOT.
One of the reasons of using a cheaper LQ4 was so I could tinker and if I blow it up it's not that expensive compared to LS1 or others, but I'm not confident enough or knowledgeable enough to build a tune from scratch.
HPTuners
Was hoping there was some other repository or maybe someone here might offer a safe baseline tune for this somewhat common recipe to leapfrog me up to having tables that are "close" and have the stall shiftpoints already close and have the misfire detection handled and maybe a dozen other things I wouldn't even be aware of fixed before I start going into the nuances that are different from motor to motor even with exact builds.
I guess if the community doesn't have that then I'll maybe start calling some tuners and see if they'll part with one of their baselines for a fee. I really thought the community worked differently than that.
Restricted User
Get something that's close. Don't worry about the engine size or gearing. I'd look for an A4/LS1 tune with a cam similar to yours and start from there. Engine size and gearing take a couple of seconds to change.
EDIT: wanted to mention that I do this remote control stuff all the time for my work and as long as I am in 4G coverage it is every bit as fast as using a local computer for the remote user. And, if using Verizon, I know that I can do a simultaneous voice call.
what do you charge for a base tune ? im doing a 5.3 243 heads with btr stage 2 turbo cam . ls6 intake . 7875 turbo 80 injecters th400
