F body operating system VS C5 Corvette
Old 06-18-2018, 04:43 PM
robert19890412's Avatar
Default F body operating system VS C5 Corvette
Is there a difference?
I recently purchased an online tune from someone the pcm came out of a F body.
From my understanding they are not the same operating system. While attempting to install the pcm and do the relearn I keep getting warnings flashing across the screen.
My old pcm only has the 1635 code still works and has none of these codes when i switch back to it.
Old 06-18-2018, 05:21 PM
LSX Power Tuning's Avatar
If its a 411 pcm you can flash a 1999-2002 f body or 1999-2002 corvette tune in the pcm. Both can have the same OS number but the tunes are different.
Old 06-18-2018, 05:41 PM
So why would I be having issues assuming the operating system is correct?
Old 06-18-2018, 06:14 PM
Also it is going into a 98 corvette.
Old 06-18-2018, 08:48 PM
If they did not flash a 98 corvette tune into the pcm then it will not work. A 98 camaro and 98 corvette tune have the same OS but different tunes. Without you posting the tune out the pcm no one but the person who flashed the pcm is going to know what they did.
Old 06-19-2018, 06:03 AM
He said he flashed an f body tune. Guessing that's probably the issue.
Old 06-19-2018, 09:49 AM
You can not run a 98 fbody tune in a 98 corvette, wont work.
Quick Reply: F body operating system VS C5 Corvette
