L99 swap - no cranking at all
I have purchased salvaged Camaro 2010. My plan is moving L99 engine and auto transmission 6L80 to Nova 1973. In addition, All wiring harness, ECM, and BCM are from Camaro.
After I installed the engine, did all the wiring connection, and deleted VATS from ECM, I tried to start the car. However, the engine is not cranking at all.
What are the possibilities that leads to that issue?
Not cranking? Not turning over? Or not firing up?
Did you swap the gear selector? You need to be able to tell the comp you are in neutral/ park.
Fuel system? This is a returnless style
wiring and fuses? Coils, injectors, starter should be getting power. If it was a wrecked car double check your wiring and fuses.
Any codes store in the pcm?
The car not cranking at all. The pcm has startup tune so no vats. I did not check it for any code. I used everything out of the camaro and put into my car shifting stick, wiring, fuses, dash, bcm and everything. But not the doors panel, I must try to connect the doors panels just to check because I heard that it has something to do with vats or bcm
If you used everything from donor car you dont need to delete vats.
And this helps him HOW?? Being a bit more constructive would add to this thread. Nothing you said here does that.
