E67 VSS settings - HP Tuners - Heeellllppp !!! https://cimg3.ibsrv.net/gimg/ls1tech...4fa0b296d3.jpg I'm running a Porsche 996 with a crate LS3/525. I am feeding the PCM with the Porsche VSS signal. On the Porsche it's taken from the ABS ring. The ABS ring has 48 teeth. I worked out my car does 828.93 wheel revs per mile, and should be giving 39789 pulses per mile. I cannot for the life of me work out how to input that into HP tuners. Can somebody please help? Mark from the UK. |
https://cimg9.ibsrv.net/gimg/ls1tech...c5438fc7b6.jpg Switch to advanced view. Go to EDIT - VIEW - ADVANCED. Then you should now see a lot more parameters to be able to calibrate it properly, see the attached screenshot. |
Thanks very much :) I'm in the advanced menu now. I don't suppose you would be able to mark your screen shot with all the correct setting would you? Mark. |
Send me the file and I will adjust it there, easier for me than marking a screenshot You can upload it here in the thread |
1 Attachment(s) Thank you ! Another 996 LS owner has advised the following: https://cimg9.ibsrv.net/gimg/ls1tech...2643cb7de6.jpg Note my tyre size is 285/30/18 |
© 2024 MH Sub I, LLC dba Internet Brands
