3 BAR MAP Giving me 109 kpa at idle - LS1TECH - Camaro and Firebird Forum Discussion
Notices
PCM Diagnostics & Tuning HP Tuners | Diablo | Pantera EFI
Old 01-05-2019, 05:51 PM
TXjeepTJ's Avatar
Default 3 BAR MAP Giving me 109 kpa at idle
Just installed an EFI Source 3 Bar MAP. Flashed PCM to 3 Bar OS using the linear of 305 and offset of 10.33
With the engine idling, if I pull the sensor out of the manifold (the sensor will not give me a reading it I just do key on.. engine has to be running) HPTuners scanner (logging 3 Bar MAP PID) shows me 109 Kpa
Atmospheric pressure in Houston right now is 101.5597 kpa.. 109 kpa to 101.6 kpa is a difference of about 1 psi
Anyone know if I should mess with the linear and offset? Or just leave it as is?
Anyway I can get it to read exactly correct?
TXjeepTJ is offline
Old 01-06-2019, 12:15 AM
I don't understand. You say the sensor does not give a reading, but then you say what the sensor reads?
gametech is offline
Old 01-06-2019, 11:52 AM
truckdoug's Avatar
engine idling it should read like 40-50 kPa
KOEO is should read ambient baro aka 101 kPa at sea-ish level
truckdoug is online now
Old 01-06-2019, 05:13 PM
TXjeepTJ's Avatar
The sensor doesn’t give a reading with key on engine off. Only will show me a reading when the engine is actually running
TXjeepTJ is offline
Old 01-06-2019, 05:15 PM
TXjeepTJ's Avatar
Key on engine off it won’t give me a reading
if I pull the sensor while the engine is running (same as key on engine off, since the sensor is out of the intake) I get 109kpa which is decently off from right.
Wondering if I mess with the offset I can get it to read right
TXjeepTJ is offline
Old 01-06-2019, 05:36 PM
Super Hulk Smash
JakeFusion's Avatar
Did EFI Source give you the parameters for the sensor? Are those the right ones?
My DPE 2.5 Bar, they gave me the offset and linear...
JakeFusion is online now
Old 01-06-2019, 07:04 PM
truckdoug's Avatar
do any of your sensors read at KOEO?
but yeah usually you subtract or add offset until it reads 101kPa as ambient baro at sea level
Old 01-07-2019, 12:27 AM
subeone's Avatar
y-y1=(y2-y1/x2-x1)(x-x1)
Offset linear can be found with above formula or simply laid out y=mx+b
I've had instances where KOEO the 3 bar map pid does not read, its a OS glitch. I suggest adjust the offset.
subeone is offline
Old 01-07-2019, 08:53 AM
TXjeepTJ's Avatar
Yup, reading through HPTuners posts, one of the actual programmers posted that it WILL read 0 KOEO.. annoying glitch lol
Thanks!!!!
TXjeepTJ is offline
Old 01-07-2019, 09:19 AM
Restricted User
Make sure your 3 bar OS applied correct (you did a write entire, not just write calibration).
Also, double check your MAP sensor. A 1 bar MAP on a 3 bar OS will read around 100 KPA while idling.
JoeNova is online now
Old 01-08-2019, 10:19 AM
01ssreda4's Avatar
I hate those junk chinese sensors
01ssreda4 is offline
Old 01-08-2019, 11:52 AM
MontecarloDrag's Avatar
2 Bar / 3 Bar MAP sensors with Custom OS don't give a reading at KOEO (it will show 0 in the scanner), the engine must be running to give a reading.
What I do is start the engine then use bi-directional controls in the scanner to kill the engine without closing ignition. This way it will keep reading MAP then you can check if it matches BARO
MontecarloDrag is offline
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
