T56 speed sensor question I have a LS3 running the early 24x crank and 1x cam ECU with a T56 transmission. I have no fault codes but when I come to a stop my idle stays up around 1200 rpm for 2 to 5 seconds before it drops to normal idle. Can this possibly be a symptom of a bad speed sensor? It runs fine otherwise. Thank you! |
you have a log file with that happening? |
Sorry, but not sure what you mean by a "log file". I do not have a fault code from whatever is happening. Thanks |
Thats how my 02 M6 TA was after the engine swap/dyno tune was done...was told it hangs the idle up for a few seconds until the speed sensor verified the car came to a complete stop then the idle starts to decay down to normal.....this was big cam/big cable hrottle body way to get it to cime down to a nice idle......its all adjustable with hptuners somehow |
© 2024 MH Sub I, LLC dba Internet Brands
