Misfires on all cylinders no check engine light
I have a 2006 impala ss 5.3 ls4, it bucks and surges under light acceleration when the converter is locked. Not getting any codes but it shows all cylinders are missing randomly on my scanner. It runs fine wide open or if you get in it hard enough to make it downshift. Its stock other than a cai,and cat delete with dod tuned out. Ive replaced the plugs and wires and no difference. Anybody got a idea what it could be.
When DOD was tuned out, what else was done to the tune?
The 4T65E transmission in these cars is notorious for converter issues and other issues. It sounds like the converter clutch or the valve body solenoid for the TC clutch is failing. There is a valve in the valve body that starts to wear and causes issues or if the car had DOD for some time the DOD function in the motor causes the converter clutch to wear down to bare metal. This causes surging, shudders, cruising rpm instability which can cause misfires.
