5.3 swap wont rev remove grd frm maf and works 86 c10 5.3swap it bogs when I hit the throttle. Yesterday removed the ground pin from the maf and it accelerated fine but high idled for 5or 6 seconds. I would appreciate any help or ideas |
It's now running in speed density mode. Removing the ground killed the MAF. You likely need a new one, or the old one just needs a good cleaning. |
Its a new one i bought from eBay and when i connect the ground back it idles smooth as if it didn't have an aftermarket cam |
I just ordered a new one i will tell you that What it does. |
When it comes to sensors and such, you should always use either genuine GM or other KNOWN good brands. Unless you KNOW the quality of the sensor, I would shy away from eBay. |
© 2024 MH Sub I, LLC dba Internet Brands
