Q: Flow straighteners for MAF, improved MAF Tune?
So for those of you that have run a straightener, were you able to just shove it down the intake tube and have it stay in place? My concern is that there is no easy way of retaining the straightener. I worry that with high airflow the straightener may get pulled down the intake tract.
My only thought would be to drill some self tapping screws through the intake tube and seal them with RTV.
I drilled a couple holes in front and behind the honey comb. Installed some long bolts and jb welded them in. The bolts threaded portion holdes the honey comb in place.
They help alot with the ls3 and ls7 card style mafs. **** the 85mm mafs had honey combs from the factory. There was a reason gm used them!!
