LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   Won't stay running (https://ls1tech.com/forums/pcm-diagnostics-tuning/1939076-wont-stay-running.html)
K!ssmySS Jul 10, 2020 02:08 AM
Won't stay running
This is becoming a beadache car wont idle with iat sensor plugged in but will idle fine with it disconnected i have a new sensor and Its getting its proper voltage. Thanks
Darth_V8r Jul 10, 2020 07:47 AM
Moved thread here. Deleted duplicate thread.
LilJayV10 Jul 10, 2020 12:12 PM
You could give just a little more information...............
I'd post my crystal ball meme but I don't have it on this computer...
K!ssmySS Jul 10, 2020 02:54 PM
lq9 h.c.i, 4k stall tuned on speed density, 0411 pcm the car will run but a little before stalling out with sensor plugged in and has a hard time starting when the motor is up to temp, if i unplug the sensor it fires right up and runs good
LilJayV10 Jul 10, 2020 03:04 PM
datalog and tune?
G Atsma Jul 10, 2020 04:35 PM
Originally Posted by K!ssmySS (Post 20268005)
...............the car will run but a little before stalling out with sensor plugged in and has a hard time starting when the motor is up to temp, if i unplug the sensor it fires right up and runs good
WHICH sensor?
K!ssmySS Jul 11, 2020 06:16 AM
Originally Posted by G Atsma (Post 20268028)
WHICH sensor?
the iat
G Atsma Jul 11, 2020 09:50 AM
Originally Posted by K!ssmySS (Post 20268160)
the IAT sensor
Fixed it. I thought it was a typo in your first post. Acronyms should always be capitalized for better clarity.
You might have a bad IAT sensor.
Darth_V8r Jul 11, 2020 12:27 PM
I wonder if the tune is overly lean. With iat unplugged you get -39 degrees and it runs pig rich. So if it is running good without it you are very lean.
Also consider a smoke test for vacuum leaks
© 2026 MH Sub I, LLC dba Internet Brands
