If I disconnect the MAP sensor can I tune my MAF?
Old 09-06-2004, 09:48 PM
Another_User's Avatar
Default If I disconnect the MAP sensor can I tune my MAF?
I saw somebody say to disconnect your MAF to tune speed density mode. Does it work the other way around if you are not sure about your MAF calibration?
Old 09-07-2004, 01:38 PM
deezel's Avatar
No.
The MAP sensor should be quite accurate compared to the MAF - pressure sensors are a robust technology.
