How to fix "railing" O2's??
Thanks and any info is greatly appreciated.
Matt
Matt
Now if the O2s are swinging like that at WOT not good... but part throttle that's normal
Only thing performance related I can think of is part throttle response... not sure how this would be affected if you got the O2s closer to a constant 450 .. though at a constant 450 or closer to it... may set an insufficient switching code ... or could run into probs w/the PCM calculating the fuel trims... not sure though
Matt
