cruise control not working no blown fuses
Old 09-14-2004, 11:47 PM
fozziejared's Avatar
Default cruise control not working no blown fuses
cannot figure out why cruise control isnt working. no blown fuses unless there is another fuse box that i dont know about, the 2 under the hood on drivers side then in drivers door jamb. hp tuners cant do a diagnostic on that can it? let me know please. thanks.
Old 09-14-2004, 11:54 PM
2MuchRiceMakesMeSick's Avatar
Depends, is it throwing a code. I assume not.
Old 09-15-2004, 07:40 AM
John_D.'s Avatar
Mine is intermittent. It will work fine one day, and won't work at all for a week... I haven't figured out where the break down is yet. I suspect it's in the switch though.
Old 09-15-2004, 08:06 AM
SMOKINV8's Avatar
Check your taillights. They are all on the same circuit as your cruise control.
If it's an intermittent problem, it can be a bad connection in the bulb harness. Usually it's from corrosion.
Old 09-15-2004, 08:44 AM
monodax's Avatar
My cruise control quit working all of a sudden, I did some testing and noticed that my clutch pedal switch was defective as it never changed voltages when the pedal was depressed. I put a new switch in and it corrected the problem. Normally on a M6 if you depress the clutch the cruise control will deactivate. Also if your car is a M6 you can also adjust the depth of the switch as your switch may not be depressing all the way when you let your clutch out.
Old 09-15-2004, 09:20 AM
SMOKINV8's Avatar
That's a good suggestion as well, I hadn't even thought of that. Wonder how often those go out?
Old 09-16-2004, 12:35 PM
i am throwing a code that says something about a clutch switch i will check that out. thanks.
