VE tuning, baffled, 2000 c5, 30% swing, no affect!!
ive been playing w/ the secondary VE table and noticed i wasnt getting much of a change. So for the sake of argument, i Zeroed the primary VE table and I also tried to subtract and add 30 from the 20-100KPA 400-4000 RPMS and my Ltrims are still not being affected.
Please help me out here, im ready to kill this car. IS THERE some other table the C5 looks to when MAF is unplugged?
Dave
Dave
If you are resetting the trims and the maf is unplugged I dont know what else to tell you
I would make changes to the primary and then copy them to the secondary just in case the pcm is using some sort of blending
no the car idled perfectly. even w/ maf unplugged the scanner shows .32
btw pull what fuse? How is this diff then resetting trims via software?
dave
dave
pull the ecm battery fuse. Its labled in either 1 of the two panels. If you pull the fuse on your vette you will have to do an idle re-learn. I dont know what to tell you other than that and drinve for 40 minutes to make sure what you are seeing is correct
F-Bodys rule,..... Y-bodys drool. Just joking. I am all out of ideas and have started drinking so i dont know how much help for how much longer i will be
