swapping pcm's ??? I want to swap my '00' pcm for a '02' so I can use a friends hp-tunners,is this possible?? any info would be great... |
from my understanding 99+ PCMs are similar enough to swap... I'm running a who knows what year PCM in my car right now, 2000 ... it's running a 2002 Operating system |
hmmm good question. If Tuners checks the vin year digit then you may be SOL |
Originally Posted by HumpinSS hmmm good question. If Tuners checks the vin year digit then you may be SOL do you guys think this will work?? |
I don't see why it wouldn't work, except loading a 2000 hptuners file into a 2002 pcm is probably a bad idea, if it's even possible. Just modify the file that's in there, copy & paste tables if you need to. |
| All times are GMT -5. The time now is 12:48 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
