what should i chaneg on my tune now?
i was running mac mids, ory, and borla. now i have lanes true duals dumped at axle with 12" bullets and a ported and polished tb. what should i adjust now that i have changed my setup on exhaust? or leave it alone? i am using hp tuners to make the adjust
Well, you might not have to adjust anything. Check to see that your ltfts and 02s are still in line, and if they are, you prob. don't need to change anything. I don't think the mods would make a big enough impact that you would HAVE to change anything.
It depends on what you're seeing. If you see that the ltfts went a little positive, put in a little extra fuel to get them negative again. Also make sure the 02s read the same at wot and adjust pe if needed. Do some logging and tell us what you find.
