HP tuners kit came in today. MY Laptop only has usb though.
HP TUners Came in but LAptop only has USB PLug
I just got out of the hospital after being very sick these past few weeks and I was hoping to get to mess with the HP Tuners software.
Well my ThinkPad doesn't have any COM Ports and I guess I'm wanting to know which port or adapter to go buy so I can use it.
or you can get a PCMCIA Serial adapter... i'd say the Port Replicator would be the best bet, followed by the PCMCIA card, with the USB to serial as a last choice... stay away from Belkin
I have the same problem, expect I haven't ordered my HP Tuner yet. I did a search a few weeks ago and found that HP Tuner suggests this usb - serial adapter. My understanding is that this is really the only suggested adapter to use.
http://www.keyspan.com/products/usb/USA19HS/
I've heard some good things about the keyspan adapters... not sure if HP Tuners is suggesting to use them though... w/the normal reflash "write tune to car" procedure , it's failsafe ... so if others have had luck with it then should be ok
I would advise against doing a full rewrite w/a USB to Serial adapter though... no matter how good the tuning software is... during a full reflash if the USB adapter hiccups... it can kill a PCM
I've had great luck with my sewell dev. USB to serial adaptor. Never had any issues with it at all and I've had it quite awhile. Heres the link. http://www.sewelld.com/ It's only $17.95 too!
Don't Buy a Belkin it will cause you a headache. And, a empty wallet.Buy a Keyspan. The Belkin crapped out on me during a flash and fried my Pcm. Had to get a new Pcm it took me a week to finnally decide to buy a new computer.I haven't had any problems out of the Keyspan USA-19HS it cost me 29.99 at Comp USA.
BELKIN
BELKIN
Originally Posted by slow
the belkin chipset is questionable.
The IO gear, and keyspan seem to be good units.
Personally, i've flashed 98 pcm's hundreds of times with a $9 ebay adapter, and been fine (but i do keep a spare pcm in my car to be safe )
Ryan
Ryan
Seems to work fine.
