just finished H/C install on my procharged 98
Old 04-02-2005, 04:01 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
Default just finished H/C install on my procharged 98
so here's my problem it's running so rich it's hurting my eyes. but from the logs it's says it's lean stft went to +59 and ltft are at +25. and o2's stay at 20's and 30's,they only went up to 860 once. are my 02's bad? i think they got soaked in coolant when i swaped the heads. i'm also getting from 10 to 15 degrees of knock retard. did i scale the injectors correctly? i multiplied the stock 28's by 2.06. i have delphi 50lbs injectors on it that ran fine before the H/C swap. any ideas guys?????????
also i took a video clip of it running, how can host this myself?
Old 04-02-2005, 07:15 PM
well just bought some o2's for the hell of it and it's still running the same.
Old 04-02-2005, 09:33 PM
oange ss's Avatar
i got 2.00 @58 lbs, according to the FT it is runnin lean but the VCM is over correcting for it dumping way more gas than actually needed, adjust PE accordingly.......that's my theory anyway
Old 04-02-2005, 10:09 PM
Billiumss's Avatar
What are all your mods and all the specs?
We need those to help you.
Bill
Old 04-02-2005, 10:38 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,090 Likes on 718 Posts
+ltrims are rich, -ltrims are lean.
Old 04-02-2005, 11:22 PM
SmokingWS6's Avatar
I agree you o2's might of been soaked in coolant, and are now fouled over with fuel and are dead. I'd look into vette rear o2's. I've also seen extreme excess fueling causing knock, or false knock.
Old 04-03-2005, 06:14 AM
like i said i replaced the o2's and it is still running the same. so how can i correct this?
Old 04-03-2005, 06:56 AM
**edit** video didn't work
Old 04-03-2005, 07:08 AM
i need to host this somewhere better but this is all i found.
click http://rapidshare.de/files/1113674/1.wmv.html
scroll to bottom-
click free-
wait for however many seconds it says at BOTTOM-
then download-
Old 04-03-2005, 07:18 AM
oh ok so it is rich how do i correct this
Old 04-03-2005, 10:26 AM
P Mack's Avatar
Sounds like an exhaust leak to me. O2 sensors are reading the o2 from the air leaking in making your car think your lean so it dumps fuel.
Old 04-03-2005, 02:29 PM
SmokingWS6's Avatar
+LTFT means the pcm adds fuel due to a lean condition. -LTFT pcm pulls fuel from the mix. If your pegged +25 that meas the pcm is dumping in a ton of extra fuel, most likely a mialfunction somewhere, or a tuning problem.
Did you retune it for h/c, perhaps its not programed for the 50lbs injectors? did you try running with no maf? How big is the cam? is the problem idle only or when your driving. Might need to rescale your VE table big time if its a large cam. Hopefully its a blower cam with low overlap. loose harness somewhere ect.
Old 04-03-2005, 02:48 PM
9-Second Club
Ed Wright's Avatar
Unless the black smoke is really thick, your eyes burning means it is lean, not rich. Believe your fuel trims.
Good luck,Ed
Old 04-03-2005, 05:05 PM
how do i rescale ve table?
Old 04-03-2005, 05:23 PM
SmokingWS6's Avatar
https://ls1tech.com/forums/pcm-diagnostics-tuning/284479-finally-how-tune-101-a.html
https://ls1tech.com/forums/pcm-diagnostics-tuning/287094-read-me-first-tuning-docs-ve-maf-ses-lights-faqs-more-01-31-07-a.html
Old 04-03-2005, 06:21 PM
luv2spd's Avatar
Yeah, positive ltft's mean lean. You need to give it some fuel.
Old 04-03-2005, 07:50 PM
after messing with the tune all day i have the ltft and stft between -5/+5. idles ok at 850 but still getting upto 14 degrees of KR at times. also i think the two grounds at the back of the driver head are messed up and are not ground the pcm i believe.
Old 04-03-2005, 07:51 PM
oh so what do you think of the vid clip?sound good or no
