Increasing VE = Increasing LTFT's?? I drove my car 30 minutes. Used average histogram and found values of 0-7 in the LTFT tab. I increased the primary and secondary(as best I could) by half of the difference. I have only driven the car a total of 40 miles after changing the VE table but the LTFT's now show all cells that were changed now between 7-10. Should I drive another 60 miles before worrying about it? I have only reset the fuel trims once and it was right after I uploaded the new bin file with the changed Ve's. Just confused is all. |
what do the short trims say? |
After reloading the log, the AVERAGED short trims looked better with 80% of the values between 0 and -3 and the other 20% were very spotty with values ranging from 3 to 6 with an 8 and 11 single cell outliers. Do the short trims give me a better idea of what the LTFT's will look like after 100 miles? Do I only reset fuel trims after changing ve table? or do I reset then every time I start the car? Thanks for the help! :) |
when you did that initial change, did u use short term and long term? if you send me your before and after logs and the before and after tunes i can check it out, kinda hard to explain easier to show. budchevy358@yahoo.com is my email |
email sent from tigerbalm2424@yahoo.com - if you can help me get going on any other part of the tune that would be great too(just give me some ideas!!) Thanks |
| All times are GMT -5. The time now is 07:55 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
