LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   O2 sensor's (https://ls1tech.com/forums/pcm-diagnostics-tuning/314649-o2-sensors.html)
Orange Juice Apr 30, 2005 05:07 PM
O2 sensor's
I have a crack in my header that is not repairable. I am waiting for a set of Kooks to arrive. The Injector banks are noticably different. Would this be caused by my leaky header? I don't want to start any tuning until I get the new headers in but I would like to get the car running better. The idle is holding up until I come to a dead stop. I used the smoothing feature in HP tuners and that cured my idle problem but only for a short time and now the car is back to running at 2000 rpm until I come to a stop. Any sugestions.
CAT3 Apr 30, 2005 09:04 PM
If you have an aftermarket cam in it, you may need to adust the throttle follower/and airflow tables to allow for the cam. Not exactly sure which tables to use in HPT, still working on that for one of my cars, but my 00 Z had that issue, "cruise control" type and tweaked the RAF and follower/cracker tables, and it was very nice.
Yes a leaky header, and gasket will skew the IPW as well since the O2 gets doeses of fresh air.
© 2026 MH Sub I, LLC dba Internet Brands
