Fuel cut off is stock 6200, but scan shows:
When I made a few power runs to check KR and the O2s, I power shifted 1-2 and the log showed 6400+rpm How is that possible when my fuel cut-off is still 6200? I have a shift light set to light at 5,800 so I know I wasn't 600 rpm late. Just to check I slowly reved the motor up to red line and sure enough it started breaking up right at 6,200. WTF .
If I need to check something besides fuel cut-off please let me know.
As someone mentioned, it could also be your scan tool. Does it happen regularly?
I use Atap, and I have seen on one occassion a real high rpm when it didn't make sense. Had the shift points at 6400 rpm, but the couple of frames of data showed that my 2-3 shift in a fraction of a second went from
Frame 1: 6200 rpm at 48 mph
Frame 2: 6300 rpm at 53 mph
Frame 3: 6970 rpm at 86 mph (shift)
Frame 4: 4550 rpm at 61 mph
Frame 5: 4625 rpm at 65 mph
Frame 3 was way out of whack, and I am assuming it did not really jump 700 rpm and 30 mph in that split second. More typically it would be 6450 rpm and 57 mph, or close to that. So, I dismissed it as a data error. It may happen.
My scan tool is in HP Tuners and I have a 1 year old Dell 5150 laptop. I know the dash tachometer is slow in first gear, but I thought the scanner in HP Tuners would read directly from the vcm. I just can't see me hitting 6,400 rpm during a shift and the fuel cut-off never stepping in.
