SVO 30lbers in 02 Z06
Hi guys I'm looking for a little info. I have SVO 30's for my car and have searched past threads. It seems there is some debate as to wether the SVO's are rated at 3 bar or 4 bar. What does this refer to? What do I multiply IFR table by to compensate for the new injectors (I'm thinking 35.5/28.8=1.23 So, 1.23Xthe entire IFR Table)? Please let me know if I'm wrong or missing something as I'm just beginning to use HPTuners.
My car is basically stock (Kooks 1 3/4" w/cats, GHL catback and halltech trap CAI) and will be installing F-13 in the near future.
Thanks!
Thanks!
The SVO 30's are rated at 3 bar. Check out this thread on injector scaling.
https://ls1tech.com/forums/pcm-diagnostics-tuning/325156-injector-scaling-anybody-have-good-how-anybody-have-math-formula.html
Using HpTuners Unit Conversion table I entered the SVO's running 30lbs @ 39.5 psi and it came out to 36.35lb's @ 58 psi. Then divide 36.35/30 and I got 1.21. So I would then multiply the IFR table by 1.21, correct?
Thanks guys.
Thanks guys.
Thanks guys.
Thanks guys.
Actually the difference in flow is 19% as 30 SVO's only flow 34.54 at 4 BAR (58psi). Trust me I have them and it took me a wideband to really figure it out.
The biggest missbelief is that they flow 36lbs at 58psi, when actually they flow less.
If I had to do it again, i would have gone with Lucas 42lbs from the first time.
