modified car- what do i tune? wont run right
I have done the fallowing-
stage 3 heads
224/224 .581/.581 cam
Yank SS3800 converter
the car barely wantes to idle. makes no power and wants to die all the time.
I have HP Tuner. Just wondering what to change and what to change it to.
thanks.
stage 3 heads
thanks.
Originally Posted by P Mack
Start by opening your tb set screw a turn or so.
what do your trims look like, any other syptoms besides misfires se codes
as far as the idle i would lower cranking ve by 20% and add 35 % to the idle air table and bump up idle rpms to around 850 that will at least get it running, you can tweak it later, so u can find out what the bigger problem is if its misfiring bad it should set codes. need to know more
oh and i would reflash to the stock tune then adjust the idle and go from there you never know what has been changed if "professional" tuners have messed with it
