any one with HP Tuners have a High Octane Spark Tab I can see, has a cam like mine?
have done the search thing at the Bin .No one has a tune in there that matches my Cam My Cam is 230 227 @.05 on a 112 Anyone have a High Octane Spark table I can see, that has a cam close to mine? Thanks
Scott
Scott
Originally Posted by SmokingWS6
What kind of problems are you haivng with timing?
Scott
alot of that might be false knock aftermarket springs valves make alot of noise same with exhaust. Have you tuned trims, that helped alot with mine I milled my heads .050. After that I might look at knock sensor calibration tables if you still have it after that I would start pulling timing. I have the exact same problem at 1600 rpms under load with converter locked in 4th. Its very spuradic . I would also run some race gas 105 or 110 and see if it goes away, if its still there then you know its false.
