LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   tuning ltft's.. changes dont do anything? (https://ls1tech.com/forums/pcm-diagnostics-tuning/344688-tuning-ltfts-changes-dont-do-anything.html)
cheechz Jun 30, 2005 10:34 PM
just started trying to tune w/ hptuners after tr224 cam install. using the ls2tuninginfo.doc file..
A. In the VCM Editor>Edit>Engine Diagnostics>General>MAF Sensor Fail Frequency = 0. This will set a P0103 code and turn on the SES light. Ensure that the P0103 DTC is enabled and you are seeing P0103 in the DTC list. Don’t worry about the DTC at this time.
B. In the VCM Editor>Edit>Engine>Spark Advance>Main Spark vs. Airflow vs. RPM Open Throttle/Moving. Copy the High Octane table to the Low Octane table. The computer reverts to the low octane table when a MAF failure is indicated, this will assure optimal timing.
C. Start the VCM scanner>Histogram display. File>Connect. Then Tools>VCM Controls>Fuel & Spark>Fuel Trim Learn>Reset Fuel Trims.
the block of ltft values below 2400 rpm's and 55 kpa are all at -12. i have now subtracted 14 (in 2 separate steps) from the primary PE/RPM/MAP table and i am still getting -12 for that same block of values. am i missing something? my other LTFT values above this range are all between 0 and about -6 or so.
thanks in advance..
felton316 Jun 30, 2005 10:40 PM
What year vehicle is it?
horist Jun 30, 2005 10:47 PM
^^^ ditto ... is it a 2k or earlier?
cheechz Jun 30, 2005 11:02 PM
2000 TA.. i'm waiting in anticipation! i didnt know year had anything to do with it..
P Mack Jun 30, 2005 11:07 PM
You need to make changes to the secondary ve table as well for it to do anything for 1998-2000. Make the changes to the primary, then copy every other row to the secondary.
cheechz Jun 30, 2005 11:19 PM
cool.. thanks! i'll give it a shot.
© 2026 MH Sub I, LLC dba Internet Brands
