Car won't stop starting Ok just did a converter change out, and had the batt unhooked for a day or so, Well I went to hook it back up and the car tired starting, So i checked the keys, they werent in it, I tired again....same thing. So I put the key to the on pos, and still ......it tired starting. What the hell do I do to get it to stop that. Thanks guys |
sounds like so wires going to the starter are grounded. Mkae sure no wires are pinced |
The wire on the large terminal of the starter solonoid it touching the wire on the small terminal. Make sure the tab on the large lug is going into the slot on the solonoid, then tighten the nut. |
ok lol well I went to do this a droped the starter on the Oil sense in the side of the pan, I'm thing this is the oil level sense. Is this Importiant or Can i do with out it untill I can get to the store to get a new one, I gave up on the starter for now, Cuase i'm not sure what the car will do with this senser broken, And I didn't see anything wrong on the back of the starter, How many wires just The red and the one that looks like is it connecting something right |
1 Attachment(s) As long as you are not leaking oil from the broken sensor, you should be OK to run the car. Maybe this pic will help. One time I didn't get the tang on the large cable in the slot in the plastic and it was touching the small terminal. The starter engaged as soon as the battery was connected. Also, if you connected the large cable to the other large terminal on the starter, it would crank as soon as the battery was connected. |
Ok i'll run out there and try that now I just hope that Sense don't do ahole lot. |
| All times are GMT -5. The time now is 06:01 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
