10* knock, WTF?
So far the only connection I can make between them all is, the RPM's are low (between 1000-1550rpms), the TPS% is low, and advance just before the occurance is below 35* .
When the advance is above 35*, I havent seen any knock in those area's. So should I maybe add timming to those area's to see if that will get rid of the knock I experience there? Or am I right out in left field here. I have a chart attached of the latest suspect.
could also be false knock with an aftermarket valvetrain and aggressive cam lots of noise might look at adjusting knock sensor level at low rpms
hopefully someone else will jump in if im off
I'd like to see what the maf and injectors were doing at the time. With the headers and cam i'm guessing it needs a good VE tune, possibly maf.
104 in canada
I figured it was 70* and you were on stock fan programming. sent pm back
