Ecm won't reset? Ok I got a SES light the other day, found 2 bad air check valves (one of them had a crack in it) , replaced them and reset the ecm, SES light won't go away, it's there even before I start the engine, and won't go away even if I drive it. Since I live in Sweden it's not very easy to find anyone that can scan it?? Any Ideas, Is there something that could trigger a SES without starting the engine? Tanks |
Forgot to mention that the car still runs super! |
Anybody??? |
What was the procedure you used to reset the pcm? |
Originally Posted by Mustang5.Ohater What was the procedure you used to reset the pcm? |
Disconnect the PCM that will give you a reset... |
Originally Posted by D_Run Disconnect the PCM that will give you a reset... |
Originally Posted by jimsss Yep, but the prolem is that SES comes back, without starting the engine... It will always be there until you start the engine. |
Originally Posted by jay_99z It will always be there until you start the engine. Oh, maybe it is :) Then my problem is that won't go away, doesnt matter, gettin' it scanned tommorow morning! |
Originally Posted by jimsss Oh, maybe it is :) Then my problem is that won't go away, doesnt matter, gettin' it scanned tommorow morning! |
Good luck man. |
Originally Posted by jay_99z Good luck man. |
Ok, got it scanned, p0412 and p0418, so I checked the air pump fuse....blown! Problem is that it keeps on blowing every time I replace it?? Anybody know what could be wrong? |
Air pump is crap? |
Yep, I think it is.... |
Throw that shit away :) Iīve throw mine away long ago... |
| All times are GMT -5. The time now is 04:10 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
