HP Tuners Locking Up?
You guys have any problems with HP Tuners locking up on you? Every now and then while I'm scanning it'll lock up. Its annoying because I have to stop the scan, lose all the data, and then start scanning again to fix it. I also get the "attempting to reconnect" message alot. Anyone know why?
My laptop using the Radio Shack usb/serial adaptor won't lock me up, but most of the time hard boots my computer after saving a log session. I'm using EFI Pro more and more now because of that.
I had that problem. It would every once ina while loose communication with pcm. Then it would get a connection and would be in slow mode. It kept getting worse and worse. I found it was my cable. Or the serial cable part of the cable. I guess it had partially broken wires in the cable were it attaches to the laptop. I guess from setting it in the seat and bending the cable there by the connector.
I replaced the serial cable and have not had a problem since.
I don't use a mouse, just the keypad. I also don't use a USB adapter, just the serial cable into the laptop. Maybe the serial cable is bad. It only a few weeks old though. It does the reconnect thing alot. Locks up every now and then. Very annoying.
It happened today while I was trying to log. I would get the attempting to reconnect every five seconds, and it locked up twice. It is VERY annoying, to say the least! I emailed HP tuners support, I really hope they have an answer.
Jason
Jason
