LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   Can't get trouble codes (https://ls1tech.com/forums/pcm-diagnostics-tuning/383613-cant-get-trouble-codes.html)
maganeztransam Sep 21, 2005 10:26 AM
I've tried to get the trouble codes out of my 94 trans am with a scanner ( a cheaper one, those from wal mart) and with a paper clip but the only thing that happens is the fan turns on and no codes or blinking. any ideas?
barito48 Sep 21, 2005 04:24 PM
OBD-1, if you jumper the mode select To Gnd. in the ALDL connector you should get the fan as well as at least a code 12 (flashed on the Check Engine Light). Does the Check Engine Light come on steady with just the ign. on?
maganeztransam Sep 21, 2005 06:38 PM
No code 12 and the check engine light keeps turn off
2001NBMZ28 Sep 22, 2005 12:43 PM
I think you need to use a scanner for '94
http://shbox.com/1/dlc2.jpg
barito48 Sep 22, 2005 01:05 PM
no code
1 Attachment(s)
I think if you have the upper connector it should work- not sure with the lower. 94-95 were transition years to obdii.
maganeztransam Sep 22, 2005 11:13 PM
I guess I do need a good scanner. Bad luck. damn it.
© 2026 MH Sub I, LLC dba Internet Brands
