LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   PCM Diagnostics & Tuning (https://ls1tech.com/forums/pcm-diagnostics-tuning-7/)
-   -   AFR 205's timing? (https://ls1tech.com/forums/pcm-diagnostics-tuning/391877-afr-205s-timing.html)
marine02ss Oct 8, 2005 01:32 PM
AFR 205's timing?
I just installed afr 205's,fast 90/90 combo,hooker lt,02"ls6 cam What do you
recommend for total timing on the car ,car runs great on stock tune I still have stock injectors 2002 Ca :) maro SS
Patrick G Oct 8, 2005 03:58 PM
26 degrees at peak torque and 28 degrees at peak hp is a safe place to start.
© 2026 MH Sub I, LLC dba Internet Brands
