No MAF signal? Problem, won't run! Today I was driving home at 55 when the car sputtered and died. I coasted to the side, started it up and it idled OK at first then sputtered some. WHen I gave ut gas it'd rev some and die then rev back up. I have EFI live, so I hooked it up. TPS is good, IAT was 104, the MAP sensor was reading, but the MAF flow stayed at .31 and did not move. So I swapped my buddies SLP 85mm on and same thing. The Injector load was only at 2-4%, but I assume with no airflow it will not increase. The wiring seems OK up to the MAF, but I didn't get under the car tonight. I run a stock MAF with Tybrne ends. The wires on the MAF sensor look ok. Any ideas or thoughts? |
Well, did some more searching, it has a blown engine sensor fuse, so I have a short somewhere. My O2 sensor harness is a little messed up, it might be that. I'll climb under the car tuesday and sort it out. Too tired to mess with it tonight :-) Ed |
Thank's to your post, I found my problem my car did the same thing friday night. I found a engine fuse blown.do you know what can cause this short if you can keep me up to date. |
Mine was an exposed wire on the O2 sensor. Taped it up and all is good so far. You must have some damage somewhere, should be sorta obvious. Just check all the harness leading to the sensors. Some head/cam cars have reported rubbing the harness behind the engine if it is not secured. Good luck! I am fixed, and back on the road! Ed |
Thank's for the help. I found a O2 sensor wire that was melted down by the header. I fixed it now is running good. |
| All times are GMT -5. The time now is 10:11 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
