Help Question!! Car Misfires/Won't Idle
First off, I tried reading as much as I could before I posted this, but I couldn't find a DEFINITIVE answer as to what might be wrong.
The car is an '02 SS M6. 224/224 114 LSA cam, ported heads, long tube headers, ORY pipe.
The car ran perfectly until I started it up yesterday afternoon. It started up fine and drove normal for a few minutes, then it started to sound weird, like it was missing. It got worse and then started sounding like it was going to die at stoplights. I parked it and hoped it would clear up after the engine was started again.
A few hours later I came back out and tried to start it. It fired but then immediately died. Then, I had to open the throttle 1/2-3/4 of the way to get it to start and idle. Now it wouldn't stay idling at all. Just before I parked it, I started hearing ticking coming (hopefully) from the valvetrain.
I put pulled the codes with a predator and came up with
p0101 - maf circuit range/performance
and
p0300 - random/mulitiple cyl. misfire detected
Any ideas?
This car was professionally tuned last year, there were NO mods recently done to this car and it has run perfectly since the tune.
Any ideas?
Thanks in advance!!
-Bryan
From what I have read so far, the PCM Ign, PCM Bat, and Eng Sensor are the 3 most important fuses for the problems I'm having (idling problems and low-rpm stumbling with MAF error codes). Does that sound right?
Either way, those 3 fuses all look to be intact, although I haven't pulled them to hold them up to the light. I'm just kind of scared to mess with anything because the car ran *perfectly* before this started.
Is there any danger in pulling those 3 fuses? Will it reset the PCM if I pull them one at a time?
Sorry for the newbie questions, but I'd rather be safe than sorry right now . . .
Thanks!
It seems like a broken spring/lifter/bent pushrod would still allow the motor to start and run, although there would be a lot of ticking . . .
Would a broken valvespring normally prevent the the car from idling?
Thanks for your help, guys!
