Has anyone figured out how to get HPT2.0 to 2 step a M/T
YES
set your P/N rev limiters to what ever RPM you want it to be...and then go into your tabel for limiter vs gear and do the same thing for P/N in there too
its not great because the dam Factory software is just too slow about th eway it processes it... but it works... and does great at part throttle and then hammer into full throttle as you launch...it mediocre if you push it for a WOT launch...
Originally Posted by soundengineer
YES
Originally Posted by HumpinSS
Did they change something in 2.0 because I remember this didnt work on the 8 cylinder car but it worked on the 6's. Can this also be done with 1.7
works fine on an 8 cylinder...doing it on mine....
just a matter of having the right tables set to what you want as a limiter...
and its not the greatest...kind of sucky...but it does the job for a soft launch..or for keeping dealers from reving it up to dump the clutch to see what your beast will do..
and it works best at a part throttle condition...not so hot with a WOT pedal on the floor response
same way
you would needto launch with selector in neural and push it into gear to get the 2 step in an auto...
and launching in 3rd...is not launching in 3rd in an auto.... if the selector is in 3rd you are still in 1st at launch......it just wont allow it to go past 3rd gear with the selector in 3rd
For TH400 and 350 transmissions with a Tbrake wire in the park/neutral wire to your Tbrake setup. Activating the Tbrake on the line will also reference the rpm you have neutral set at.
Find p/n indicator wire coming from trans or shifter. Hook that wire to two switches. A wot switch under the brake pedal, and an arm switch on the console or something. Do your burnout, and pull up. Flip the arm switch. Once you depress the brake pedal the car thinks it is park/neutral because the wot switch is depressed under the pedal. As soon as you let off the brake, the computer thinks the car is in gear, and you have your normal rev limiter. Anyone know if something like this may work? I realize it may be pointless in an auto, but I think it would at least help with consistency. There would no longer be that margin of time from pushing the gas pedal down as it would already be there when you launch.
you are doing the same thing as launching in neutral that way....
all you are doing is outting the shifter in control of a switch instead of at your hands...no dfference than what I stated.....
YES
Its should work fine....
just the P/N cutoff and resume in teh main page and then the cutoff rpm vs gear table the p/n only...
I drive an M6...and I have a buddy with an A4...I told him to do exacty this..and he says it works for him...so I am not sure why its not happy on your car.
